Can't connect
May 19th, 2008
I have some problems with a aironet 1130ag access point.
it lost signal strength over the period of a week so i did a factory reset on it. now, after setting it back up (very basic) i can't connect to it at all. can't descover it or connect. it has an ip and you can ping it.
Thanks in advance for any sugestions.
jeromehenry_2 Mon, 05/19/2008 - 23:41
Is in in LAP (LWAPP) or autonomous mode? Can you telnet to it? Check if radios are on if it is autonomous... if it is in LWAPP mode, try debug LWAPP client from the console...
Chris Illsley Tue, 05/20/2008 - 04:55
Telnet or console to it, check the radios are up, radios are off by factory default.
Chris Illsley Tue, 05/20/2008 - 04:58
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
