2801 - ccme.html - does it exist?
May 19th, 2008
As above, can I access the web config part by using the above address on my 2801? I try it but IE just says 'done' and displays a blank white screen.
Paolo Bevilacqua Mon, 10/11/2010 - 16:53
The one given above.
Or, you may be using the wrong version GUI files for the running IOS.
Charles Hill Mon, 10/11/2010 - 17:16
How do I verify if I have the wrong version?
Here is a debug from an attempted login.
Oct 11 17:10:40.979: its_urlhook url: /ccme.html, method 1
Oct 11 17:10:40.979: Mon, 11 Oct 2010 17:10:40 GMT /ccme.html auth_req
        Protocol = HTTP/1.1 Method = GET
Oct 11 17:10:46.971: its_urlhook url: /ccme.html, method 1
Oct 11 17:10:46.983: HTTP: Priv level granted 15
Oct 11 17:10:46.983: Mon, 11 Oct 2010 17:10:46 GMT /ccme.html ok
Oct 11 17:10:46.987: telephony_service_server_get_action url:/ccme.html
Here is the IOS.
Paolo Bevilacqua Mon, 10/11/2010 - 17:17
You need to download the files specific for your version.
Anyway, the GUI is next to garbageware, so you're not loosing much.
Charles Hill Mon, 10/11/2010 - 17:19
Appreciate it.  I agree about the gui, however this is for lab purposes only.
mzsaad1234 Mon, 12/19/2011 - 11:22
Even though you won't be able to see ccme.html file on the flash but it would still work.
I had same issue. However I was able to fix it.
First, make sure you have the correct files extracted. Use this command:
archive tar /xtract tftp://xxx.xxx.xxx.xxx/file.tar flash:/
Secondly, make a note if you created a folder on flash and put the GUI files on there? If you did that, you will have modify ip http server command on the router.
I extracted the files to this folder on flash:
So I modified the ip http command to:
ip http path flash:CME8.6.0GUI
Then it should work.
