Cisco bridge root nonroot setup
Answered Question
May 19th, 2008
I just want to check that when setting up two 1310G bridges in root and nonroot mode that the root bridge does not need the nonroot units MAC address entered in anywhere.
The reason I ask is I recently replaced one but the replacement did not work. The config is sound and from my testing the unit appears to be OK, just wanted to rule any kind of association issue out.
Kieran
Correct Answer by andrew.prince@m... about 9 years 2 months ago
Kieran,
NO they do not need to know about the MAC addresses - generally, but they do need to know what SSID/WLAN to associate to = infrastructure WLAN. If you have more than one, the non-root cannot assocciate, as it does not know which one to use?
HTH.
Overall Rating: 5 (1 ratings)
Correct Answer
andrew.prince@m... Tue, 05/20/2008 - 01:41
  • Green, 3000 points or more
Kieran,
HTH.
chakravorty Tue, 05/20/2008 - 02:08
There is only one root bridge to associate to. Thanks for confirming my suspicions, i'll give it another shot and if it does not work at least it's been ruled out.
Thanks, Kieran
Trending Topics - Security & Network
