Meetingplace failure to send email
May 19th, 2008
I use MP 5.4 with SMTP email supportat the same level. I am having a problem where the emails are not being sent out, due to a failure in the MPNOTIFY:
MPNotify (0xb90) Information:[4] MPSMTP - Error ocurred: IDispatch error #17
There is much more doc. I have but I am finding people who had this same problem, but were told to upgrade to MPSMTP/NOTIFY version 6.
Can I just upgarde the MPSMTP/MPNOTIFY component to version 6 while other components are at version 5.4?
Thx in advance
smalkeric Fri, 05/23/2008 - 06:56
SMTP failing to send notifications seems notify and smtp services were not synched up need to restart mpnotify and mpsmtp services. Could you please check the mailbox of th eadministrator/User. Whetehr itis pointing to the correct mailbox int eh Meeting place Gateway.
noeparenteau Fri, 05/23/2008 - 07:07
I did perform the steps you indicated, but with no change.
I did get a lead from another gentleman from India, he had the same problem. His solution was to upgrade to the MP SMTP/Notification gateways. I did so:
Unit 16 Smtp:GW v5.4.11.0 Ok
Unit 16 MPNotify v5.4.11.0 Ok
emails are flowing correctly in all cases (add/modify/delete).
Rhonda Shepard Wed, 06/04/2008 - 04:51
MPSMTP 6 is not compatible with 5.4.
You will find some troubleshooting info here (even though it says 5.3, it is the same troubleshooting). Look under the section: Viewing Server Notification Status.
You can learn more about MeetingPlace by getting training at
