BCMSN Passing requirement
Answered Question
May 19th, 2008
What is the max score on the BCMSN and what is the passing requirement?
This is my first test within the CCNP and I believe that I am almost ready for it, but just wanted a heads up of what I need to look for.
Richard
Correct Answer by Pravin Phadte about 8 years 10 months ago
As per my knowledge it should be 805/1000.
Check it out.
Let me know if this helps
Overall Rating: 5 (1 ratings)
jrensink78 Mon, 05/19/2008 - 18:43
I believe score ranges for cert tests are 300-1000. Cisco doesn't publish passing scores. It's probably in the upper 700s.
But knowing the passing score won't do much for you. If you are feeling pretty confident, go for it. Worst case, you fail. But then you know how close you are to passing and what your weak areas are. So you still gain something from it.
Correct Answer
Pravin Phadte Tue, 05/20/2008 - 08:44
  • Silver, 250 points or more
Check it out.
