CRS Schedule Reports on CCX 5.0(2)
May 19th, 2008
Hi all,
i setup CCX Express 5.0(2)_Build064.
If i try to setup a scheduled report, i can export only as .csv, .xls, and .rtf (3 options).
On Cisco CRS Historical report User Guide it says that "scheduled" report can be exported as .pdf, .csv, .xls, .rtf, and .xml
Someone known if this is a bug?
Setup was done in Italian Languages
Diego
bwilmoth Fri, 05/23/2008 - 13:11
  • Silver, 250 points or more
could you please collect the following logs.
MIVR - C:\Program files\wfavvid\Log\MIVR
MCVD - C:\Program files\wfavvid\log\MCVD
Have Detailed level tracing enabled for CCM SDI/SDL and CTI SDI/SDL from the CUCM nodes which have CTI port and Gateway registered with it.
