firefox 3 (rc1) and ie7 doesn't like IRPT demo cert
May 19th, 2008
well i am sure you all tried ie7 w/ web gui on ironport. they dont like it.
firefox 3 rc1 actually requires u to add it to exclusion site...or maybe turn off some cert checking...
jaigill Mon, 05/19/2008 - 19:33
  • Cisco Employee,
The Ironport ESA is shipped with a self signed demo cert. As a result of this most browser will generate cert errors. These errors will go away if you purchase a cert from a know CA(Verisign, Thwate, etc.).
Bart_ironport Tue, 05/20/2008 - 09:06
Or alternatively, create your own internal CA and distribute its root certificate to the clients. You can then use that CA to generate a certificate for your ironport, and any other internal ssl sites you may have.
If its just for the management interface, that should be sufficient.
Firefox 3 has indeed made it very complex to access websites with self-signed or expired certificates. Not a bad thing, people always click OK without reading, but it will prevent joe average from accessing any websites with self-signed certificates.
