GUEST LAN BUGS in 4.X and 5.X
May 19th, 2008
There are some issues with the guest lan feature in all releases.
1) No CLI command to set Peer-Blocking
2) Enabling DHCP REQUIRED in the GUI prevents any settings to be saved. It works in CLI.
Can anyone tell me what a GUEST-LAN client's default gateway should be? Is it the IP of the egress interface or the IP of the upstream router ?
mchin345 Fri, 05/23/2008 - 12:34
  • Silver, 250 points or more
I think you are talking about Guest VLAN. When you configure a guest VLAN, clients that are not 802.1x-capable are put into the guest VLAN when the server does not receive a response to its EAPOL request/identity frame.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_20_se/configuration/guide/sw8021x.html#wp1026004
armonk_netdesk Thu, 05/29/2008 - 12:24
No, I am talking about wired Guest-Lan capability in releases starting with 4.1.
Another bug I just found in the new 4.130 release is that when the controller is rebooted it enables AUTO-ANCHOR on the GUEST-LAN and there is no way to disable it. Here is the SHOW output. Notice that AUTO-ANCHOR is enabled and no mobility anchor controllers are configured.....
(Cisco Controller) >show guest-lan 1
Guest LAN Identifier............................. 1
Profile Name..................................... Wired-Guest
Network Name (SSID).............................. Wired-Guest
Status........................................... Enabled
AAA Policy Override.............................. Disabled
Number of Active Clients......................... 0
Exclusionlist Timeout............................ 300 seconds
Session Timeout.................................. 36000 seconds
Interface........................................ wired-guest-out
Ingress Interface................................ wired-guest-in
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Quality of Service............................... Bronze (background)
Radius Servers
Authentication................................ 172.20.192.150 1812
Accounting.................................... 172.20.192.150 1813
Security
Web Based Authentication...................... Enabled
--More-- or (q)uit
ACL............................................. Unconfigured
Web-Passthrough............................... Disabled
Conditional Web Redirect...................... Disabled
Auto Anchor................................... Enabled
Mobility Anchor List
GLAN ID IP Address Status
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
