E1 R2 - PSTN Incomming calls are not working
May 19th, 2008
Hi all
I have IP Telephony configured with a 3845 as Voice gateway here in Mexico City with CCM centralized in US so I am adding extra E1 R2 but for some reason the Incoming PST call are not working
Currently we have three E1 R2 up and running 100 % well but this new one only send busy tone.
The TELCO said the they are sending the last four digits 32... As other E1 but for some reason we still receiving busy tone in PSTN incoming calls.
In the CCM we are using international format for Dial plan ej. 5255852532..
Look my Dial peer and translation rule configuration, the new DID range is rule 4
Note : the others E1 has the same config in CCM and router and are working ..... is strange
controller E1 3/0/1
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-30 type r2-digital r2-compelled ani
cas-custom 0
country telmex
answer-signal group-b 1
trunk-group PSTN_E1R2_MCM_TG
trunk group PSTN_E1R2_MCM_TG
voice-class cause-code 1
hunt-scheme sequential both up
translation-profile incoming IN_PSTN_E1R2_MCM_TP
translation-profile outgoing OUT_PSTN_E1R2_MCM_TP
voice translation-profile IN_PSTN_E1R2_MCM_TP
translate calling 11
translate called 12
voice translation-rule 11
rule 1 /^............$/ /+52&/ type national international
rule 2 /^..........$/ /+52&/ type national international
rule 3 /.*/ /+&/ type international international
voice translation-rule 12
rule 1 /^[0-1]..$/ /3&/ type unknown unknown plan unknown unknown
rule 2 /^[2-4]..$/ /5&/ type unknown unknown plan unknown unknown
rule 3 /^3..$/ /3&/ type unknown unknown plan unknown unknown
rule 4 /^2..$/ /3&/ type unknown unknown plan unknown unknown
dial-peer voice 430 voip
preference 1
destination-pattern ^32..$
voice-class codec 1
voice-class h323 1
session target ipv4:192.188.174.41
dtmf-relay cisco-rtp rtp-nte
ip qos dscp ef signaling
no vad
dial-peer voice 431 voip
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:192.188.174.8
no vad
Some Ideas how can I be sure who many digits we are receive from Carrier?
Thanks and regards for your help
paolo bevilacqua Mon, 05/19/2008 - 14:44
  • Hall of Fame,
    Founding Member
Can you take a "debug vpm" signal with
term mon" for both circuits and compare ?
