AIM-CUE not support 3.1.1
May 19th, 2008
I cannot install CUE 3.1.1 on my AIM module. What is the latest CUE version that supports AIM?
I would like to do AA scripts inside the CUE GUI like in 3.1.1.
Could I build a script in 3.1.1 and upload it to 2.3 and work?
Thanks in advance
Overall Rating: 3 (2 ratings)
paolo bevilacqua Mon, 05/19/2008 - 15:16
  • Hall of Fame,
    Founding Member
I have upgraded many aim-cue to 3.1.2
What is yor exact problem ?
You need to create scripts with the same version of the editor as the CUE. Unfortunately that is a bit of a problem because apparently different versions of the editor cannot coexist in the same machine.
aciscolook Mon, 05/19/2008 - 16:08
The CUE 3.1 Installation and Upgrade Guide states on page 27:
These procedures are available to systems with a network module........ CUE 3.1 does not support the 512 MB AIM-CUE.
I'm not sure they just don't mean the installation procedures....How do you install the 3.1.1 on an AIM module?
paolo bevilacqua Mon, 05/19/2008 - 23:28
  • Hall of Fame,
    Founding Member
Hi, to be honest I didn't now looked at that, perhaps I have 1MB modules.
I just followed the upgrade procedures and it did go fine. And yes it works with CME 4.2
aciscolook Tue, 05/20/2008 - 00:33
This is on a UC520 platform. Is the AIM module on CF? I thought AIMs were on motherboard. Is it possible to upgrade to 1GB AIM on the UC520?
I tried generating scripts in 3.1 GUI editor and transfer over to 2.3 but it didn't accept it.
I don't understand why they wouldn't interoperate. Aren't scripts generated in the CUE Script Editors the same? Can't these scripts be used across versions of CUE?
Thanks for helping
