CRS historical report unable to login using client
May 19th, 2008
Dear all,
I've been trying to log in to the CRS historical report and i keep getting the error message " an error occurred while attempting to communicate with web server. check your user id and password and try again". The thing is that i have configured the user at the historical reporting> user management.
I am able to login to the CRS supervisor page using the same user ID. Any idea what am i missing here? I've followed the steps in the configuration guide. Thanks in advance.
Did you change the authentication mode of the MSDE/SQL Database.
It should be Windows Authentication Mode and not Windows + SQL.
If you have a CCM v4.X try to mount the IPCC database with te enterprise manager on the CCM to verify the Authentication Mode.
Please Rate this post
Hope it helps
Remy (France)
wboonshen Mon, 05/19/2008 - 22:40
I don't think i've changed the authentication mode. How do i go about to changing that? anyway, i am using CM5.1.
richb1971 Wed, 05/28/2008 - 07:41
Did you get this sorted? I'm having exact same problem on CCX5 and CUCM5.
Rich
wboonshen Wed, 07/09/2008 - 01:23
Problem was resolved after i've reinstalled the IPCC. According to TAC, some of my files were corrupted and needed a fresh install.
