flymen331 Mon, 05/19/2008 - 20:36
Thanks Edison.
But if the bandwidth over 100Mbps, may I use PA-POS-OC3 or PA-A3-OC3? Which should be better?
Edison Ortiz Tue, 05/20/2008 - 05:35
  • Hall of Fame,
    Founding Member
What kind of physical hand-off are you going to receive from the provider?
The modules you mentioned above are for Packet-Over-Sonet and ATM Circuits respectively.
The module I mentioned is for DS3 (T3) connections.
Once you get that information, you can purchase the 'right' module, not necessarily the 'better' module as the 3 modules serve a different purpose :)
__
Edison.
