ACE rserver failed connections
May 19th, 2008
I'm running an ACE appliance with software version 1.7(a). I have rservers that are giving me about a 1:1 good connection/failed connection ratio.
1) How do I tell what is causing the ACE to say the connections are failing?
2) what is the fix?
I am using server reuse on these rserver policies.
Geoff
Gilles Dufour Tue, 05/20/2008 - 00:53
there is a bug a A1.7 releases that makes the appliance count any connection closed by a RESET as a failure.
Some servers/clients always use RESET instead of FIN.
This should be fixed in A1.8 which was just released yesterday.
Gilles.
