Problem ISA with Cisco Switch
May 19th, 2008
Dear Expert,
I would like to ask you some question:
I was configure ISA (ISA configure Vlan),and ISA connect to cisco switch 2950(configure VLan).
ISA->switch->PC
but it doesn't work.Is it possible for do like this.
Best Regards,
Rechard_hk
Overall Rating: 4 (1 ratings)
smahbub Fri, 05/23/2008 - 06:46
  • Silver, 250 points or more
The ISA or the ISM provides encryption services for any interface in Cisco 7100 series and Cisco 7200 series routers. If you have previously configured IPSec on the router and you install an ISA or an ISM, the ISA or the ISM automatically performs encryption services.
