DMVPN routing issues
Answered Question
May 19th, 2008
I have came across some routing issues while testing DMVPN in a test environment. I have used a HUB and two spoke routers and using EIGRP as the routing protocol. Tunnels are farming and can see the IP gets advertised from end to end and can ping without issues.
My problem is, eventhough the spoke routes forms a direct tunnel with other spoke using NHRP, but still the traffic is passing via hub. No EIGRP neighbour relationship is formed between spoke routers. From spoke router, when I checked the routing table it shows the next hop as the hub to reach other spoke.
I look forward to get some further info from you guys and thanks in advance.
Rajesh
Correct Answer by Giuseppe Larosa about 8 years 11 months ago
Hello Rajesh,
what you see is normal it derives from the distance vector nature of the EIGRP protocol.
You need an additional command on the hub router so that the spoke1 sees the spoke2's remote LAN subnet with a next hop pointing to spoke2.
Under the correct interface on the hub router use the following:
no ip next-hop-self eigrp
see:
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_eig1.html#wp1013026
Best Regards
hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
stephen.stack Wed, 05/21/2008 - 11:34
  • Silver, 250 points or more
HI Rajesh,
Can you post a copy of your config. How did you configure the DMVPN, SDM or CLI?
Can you only post the Tunnel interfaces on both the HUB and spokes and perhaps the EIGRP config on each also.
Stephen
kradjesh13 Wed, 05/21/2008 - 19:58
Thanks for the reply Stephan. Here is my configs.
Hub Router
crypto isakmp policy 1
authentication pre-share
crypto isakmp key cisco47 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set trans2 esp-des esp-md5-hmac
crypto ipsec profile vpnprof
set transform-set trans2
interface Tunnel0
bandwidth 1000
ip address 10.10.10.254 255.255.255.0
no ip redirects
ip mtu 1416
ip nhrp authentication cisco123
ip nhrp map multicast dynamic
ip nhrp network-id 99
ip nhrp holdtime 300
no ip split-horizon eigrp 1
delay 1000
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile vpnprof
interface Loopback0
interface FastEthernet0/0
ip address 172.17.0.254 255.255.255.0
router eigrp 1
network 10.10.10.0 0.0.0.255
network 192.168.1.0
no auto-summary
Spoke Router
crypto isakmp key cisco47 address 172.17.0.254
interface Tunnel0
bandwidth 1000
ip address 10.10.10.1 255.255.255.0
no ip redirects
ip mtu 1416
ip nhrp map multicast 172.17.0.254
ip nhrp map 10.10.10.254 172.17.0.254
ip nhrp network-id 1
ip nhrp nhs 10.10.10.254
delay 1000
tunnel key 100000
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip address 172.17.0.1 255.255.255.0
router eigrp 1
network 1.1.1.1 0.0.0.0
no auto-summary
stephen.stack Wed, 05/21/2008 - 22:54
Thanks for those. I will look at the Configs in a little more detail a bit later on. But one thing that strikes me is the subnets behind both routers. They are both 172.17.0.x. This is not for good routing. Or DMVON for that matter. Also i see eigrp is not configured to even advertise the subnets on the fastethernet interface. i.e.
network 172.17.0.0 0.0.0.255
Ok, so let's try this for a start.
1. reconfigure spoke1 so that the subnet on Fa0/0 is 172.18.0.x/24.
2. rebuild the dmvpm using SDM and make sure this subnet is advertised in EIGRP.
3. Build on the second spoke with a different subnet again i.e. 172.19.0.x/24 and build up the DMVPN form SDM again.
Try this. I will look at the NHRP commands later and give a definite answer as to why this config is not working.
Stephen
kradjesh13 Thu, 05/22/2008 - 15:10
Thanks Stephen, correct me if I am wrong. My understanding is the 172.17.0.0 is a WAN IP and in the real scenario it will be a public IP. I have difficulty in understanding why you are asking to redistribute a Public IP within EIGRP. All I am doing is redistributing the private IP within EIGRP routing table after forming a tunnel with the head end router.
Rajesh
Correct Answer
Giuseppe Larosa Fri, 05/23/2008 - 01:23
  • Hall of Fame,
    Founding Member
Hello Rajesh,
see:
Best Regards
hope to help
Giuseppe
kradjesh13 Tue, 05/27/2008 - 15:08
Thanks Giuseppe,
After using the above said command the routes are pointing directly to the spokes. When i did a trace from a spoke, the next hop is the other spoke which is fine.
One more thing which i want to know, i thought there is a neighbour relationship between spoke to spoke, but its not happening. Can any one tell me why ??
Giuseppe Larosa Wed, 05/28/2008 - 21:34
  • Hall of Fame,
    Founding Member
there isn't a direct communication between spokes because DMVPN emulates an hub and spokes topology.
the spoke to hub tunnel is always up and so the routing protocol follows this path to keep up the neighborship.
Spoke to spoke tunnel is setup dynamically when a traffic flow is present.
The NHRP protocol is used because there isn't a direct communication between spokes there is an emulation of a flat subnet but in reality a spoke asks to the nhrp server (the hub router) how to reach another spoke if necessary.
NHRP was created originally for WAN clouds like ATM, FR where you a NBMA = non broadcast multi access and where you cannot say that two routers in the same subnet are directly connected but they may need to go through some other device.
best regards
Giuseppe
