VoIP issues with 4.2.112.0 code
May 20th, 2008
Has anyone had voice issues with this code and 7921 phones. I have had to back down to 4.2.61.0 code in order to regain decent voice quality and good roaming.
Scott Fella Sun, 05/25/2008 - 20:48
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I just deployed 7921 with wlc's running 4.2.112. I had good voice quality running wpa-psk and eap-fast.
bfowles Tue, 05/27/2008 - 00:54
I forgot to add that I'm using Cisco 1250 access
points with b/g/n radios. The issue seems to be with the U-APSD function. Reverting back to 4.2.61.0 code seems to have resolved the voice problems I was experiencing.
Scott Fella Tue, 05/27/2008 - 03:41
  • Hall of Fame,
    2017 Wireless
I also deployed the 1252's with no issues. Had to run the 4.2.112 code due to the 6500 line card and inline power restrictions.
Have you looked at this guide:
http://www.cisco.com/web/AT/assets/docs/7921G_Deployment_Guide.pdf
jeromehenry_2 Wed, 05/28/2008 - 09:55
  • Silver, 250 points or more
Which firmware do you use with your 7921s? No issue with 4.2.112 for me and firmware 1.1.1.
bfowles Thu, 05/29/2008 - 07:57
The problem seemed to occur more with the 4.2.112.0 and 1.1.1 codes. If I changed the 7921 code to 1.0.5 and turned off U-APSD the voice quality was better and there were no one-way voice issues. However, reverting back to 4.2.61.0 code on the WiSM and 1.1.1 code on the 7921s solved all of the voice issues and the phones now work as expected. I only went to the 4.2.112.0 code because I need to put both radios in the 1250.
Scott Fella Thu, 05/29/2008 - 15:22
  • Hall of Fame,
    2017 Wireless
Wow.... Like I mentioned earlier, I deployed 4402's with 4.2.112 and the 7921 running 1.05 with U-APSD and no issues. They have around 45 phones.
bfowles Mon, 06/02/2008 - 02:54
Yes the 1.05 code seemed to be OK with 4.2.112.0 whereas 1.11 code definitely caused voice issues. I'll guess I'll have to stay on 4.2.61.0 until I can work out what the problem is or Cisco releases another code version. Thanks for all your feedback.
Scott Fella Mon, 06/02/2008 - 04:44
  • Hall of Fame,
    2017 Wireless
For the 4.2.112, the recommended code ont the 7921 is the 1.0(5).
