Accessing Perimiter NAT IP from Inside host
Answered Question
May 20th, 2008
I don't know if this is possible, would appreciate any insight.
I have a host on my perimeter interface (DMZ) Natted to outside with a public IP address. I want to access this host on the DMZ using its Natted public IP address (on the outside interface). So far i have no success.
Thanks in advance.
Jon
Overall Rating: 5 (1 ratings)
nojpt Tue, 05/20/2008 - 02:28
Yes, im trying to access the dmz host via its natted ip on the outside (public IP).
nojpt Tue, 05/20/2008 - 16:47
Hi Andrew,
Glad that you get out of your way to test this on your lab.
One question though, isn't it the syntax for static goes this way:
Static (high_security_int,low_security_int) low_ip high_ip netmask 255.255.255.255 ???
Where INSIDE is always the highest security interface, etc. So just wondering if the command syntax is right.
Will have to test this as well.
