May 20th, 2008
Is it possible to apply any Qos on the Tunnel. How can we I improve the traffic in the MPLS tunnel.
spremkumar Wed, 05/21/2008 - 21:27
In addition to the shiva's post do throw more on what you meant but MPLS tunnel...
are you planning to create an IPSEC or GRE tunnel on top of MPLS connection or you tried to mean the MPLS connectivity itself as MPLS tunnel.
if its a separate tunnel on top of MPLS link then you can refer the link posted ...
if its the MPLS link alone then you need to enter into an agreement with your SP to honour your markings and preserve the same till he delivers the same as an IP packet at the remote end.
