UC500 registration issue
May 20th, 2008
hi all,
i'm asking how can i register a cisco 7940 in UC500 plateform, i've the load in the flash and i do load this version but my 7940 ip phone does not be registered
plz help
Med
m.elmaaroufi Tue, 05/20/2008 - 10:34
hi
and thank you for your response, for the phone it shows configuring CM list and it still in this case, i've another phone 7912 which it is registered without pb
m.elmaaroufi Wed, 05/21/2008 - 07:26
hi,
i think that i know the cause of this pb, i must enter a "create cnf-files" to create a xml files for this ip phone, i want also know how can i activate voicemail in UC520
this is my sh run:
Router#sh run
license feature uc500-16u-upgrade
bridge 1 protocol ieee
bridge 1 route ip
telephony-service
load 7960-7940 P0030702T023
load 7914 S00105000200
load 7902 CP7902080002SCCP060817A
load 7921 CP7921G-1.0.3
load 7931 SCCP31.8-2-2SR2S
load 7941GE SCCP41.8-2-2SR2S
load 7941 SCCP41.8-2-2SR2S
load 7961GE SCCP41.8-2-2SR2S
load 7961 SCCP41.8-2-2SR2S
load 7975 SCCP75.8-3-2S
load 7965 SCCP45.8-3-2S
load 7945 SCCP45.8-3-2S
load 7942 SCCP42.8-3-2S
load 7962 SCCP42.8-3-2S
load 7971 SCCP70.8-2-2SR2S
load 7970 SCCP70.8-2-2SR2S
load 7936 cmterm_7936.3-3-13-0
load 7906 SCCP11.8-2-2SR2S
load 7911 SCCP11.8-2-2SR2S
max-ephones 10
max-dn 10
ip source-address 192.168.10.10 port 2000
auto assign 1 to 10
calling-number initiator
service phone daysDisplayNotActive 1
url directories http://192.168.10.10/localdirectory
url services http://192.168.10.10/ccme.html
time-zone 21
date-format dd-mm-yy
voicemail 4000
max-conferences 8 gain -6
call-forward pattern T
call-forward system redirecting-expanded
moh music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco password cisco
web admin customer name Customer password cisco
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern T
secondary-dialtone 0
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
mailbox-selection last-redirect-num
number 1000
label M. El Maaroufi
name Maaroufi
ephone-dn 2
number 1001
label ARES
name 1001
ephone-dn 3
number 1001
label ARES7940
name ARES7940
ephone-dn 5
number 1004
label ARES
name ARES
ephone 1
device-security-mode none
mac-address 0014.A91A.B69A
type 7912
button 1:1
ephone 2
mac-address 001A.A20F.FB83
type 7940
button 1:2
ephone 3
mac-address 001A.A264.EDA1
type 7940
button 1:3
ephone 4
mac-address 0018.191A.F6E9
type 7960
ephone 5
mac-address 0014.A91A.B2E4
type 7912
button 1:5
Frank Vo Mon, 05/26/2008 - 01:54
In addition to the "load 7960-7940 P0030702T023" under your telephony service. ensure that you have the corresponding files available under your TFTP server. E.g. tftp-server flash:P0030702T023.loads
I would open up a new conversation or open a tac case if your after a CUE (voicemail on the UC520) setup help.
Cheers
Frank
