load Sharing on Cisco Router 1841
May 20th, 2008
Dear Exper,
I would like to ask you about load sharing on Router 1841,let me tell on int f0/0 connect to ISP1(PPoE),F0/1 connect to ISP2 (Static IP) and int f0/0/0 connect to switch.and i would like to do ip address start from 10-50 go though ISP1 and ip address start from 60-100 go though ISP2.
Could you let me know how to configure and do you have sample command for this?
Best Regards,
shiva_ial Tue, 05/20/2008 - 04:09
hi richard,
you can use Policy based routing to divert the traffic to first isp and rest to remaining isp.
rechard_hk Tue, 05/20/2008 - 04:12
Dear shiva,
Do you have any document? if possible could you send to me.
thanks you for your time.
Best regards,
rechard_hk Tue, 05/20/2008 - 21:01
Dear All,
Do you have any advice on load sharing on cisco Router 1841?
Best Regards,
