PIx OS 7.2.4 vs 8.0.3
May 20th, 2008
Hi all
We are finally getting round to upgrading our Pixes (ver 6.3) to a newer version. We have been happy with ver 6.3, but are after new features, especially QoS.
Is 8.0.3 stable enough for production? What are the major differences between 7.2 and 8 versions?
As mentioned before, we are after QoS - specifically traffic-shaping based on DCSP, and also the better monitoring features on the newer versions.
osiristrading123 Tue, 05/20/2008 - 09:09
Further to the above, I see we need to upgrade to 7.x first.
A couple of questions:
1) Can we go directly to 7.2.4 from 6.3.4?
2) The upgrade documentation mentions 515 and 535 requiring monitor mode upgrade - we are running 515E's - does this apply?
3) How can we minimise the risk of being disconnected from a remote site, since the firewalls are at a data centre far away from the office. We are running non stateful failover.
Gian Paolo Boarina Thu, 05/22/2008 - 06:08
I'm going to upgrade a 6.3(5) PIX515 to 8.0(3). I've tried this software version in lab and it seems stable.
For the upgrade I'll try from remote, but with a person in the remote site for assistace.
To minimise the risk I've tried the same operation in lab a couple of times, I hope Murphy's Law will not interfere! It think write a checklist before doing the upgrade can help.
Good luck!
osiristrading123 Mon, 05/26/2008 - 11:24
We've done 4 out of our 8 firewalls. The conversion of the config works very well, but our concern now is the high CPU usage. We're seeing about 3 times the CPU usage compared to 6.3 - anyone else experience this?
