CPTONE
How can I do to know whats parameters a cptone is using?
In Brazil, in many cases, the cptone BR don't work fine and I must to user another cptones (US, ARJ, MX....). There are same show about it?
Peterson
paolo bevilacqua
You can define you own cptone (custom cptone) if you don't like the preset ones. See database at www.3amsystems.com to see how tones are made.
