Licence file; UCM upgrading
May 20th, 2008
Presently we running UCM 5.1.3.
We are planning to upgrade it to UCM 6.1.2.
We received the Device Unit License for UCM 6.1
My question is regarding the above License file, can this license file can be used on UCM 6.1.1 and UCM 6.1.2.
Due to no direct upgradation from 5.1.3 to 6.1.2 we are following the below procedure:
Firstly, We are upgrading UCM from 5.1.3 to 6.1.1 and switch over to 6.1.1 reboot and upload the above license
Secondly, we are upgrading UCM from 6.1.1 to 6.1.2 and switch over the versions and reboot the UCM(if necessary we upload the
above license file)
Please help me out
Thanks & Regards,
Overall Rating: 4 (1 ratings)
Rob Huffman Tue, 05/20/2008 - 05:42
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Krishna,
Hope all is well :) This new License file will be fine for either 6.1(1) or 6.1(2) It should only need to be loaded after the 5.1(3) to 6.1(1) Step.
Hope this helps!
Rob
