7921G and EAP-TLS
May 20th, 2008
Has anyone been able to import certificates into the phone. I am attempting to install a user certificate that was generated using a CSR from the phone. We are using an ACS 4.0 which passes the cert off to a MS AD server for validation. Any guidance would be appreciated.
Overall Rating: 4 (1 ratings)
migilles Tue, 05/20/2008 - 12:22
Yes should work fine. When creating the CSR, will need to upload the root cert for the CA that is signing cert. Then upload that signed cert that is in DER format.
Ensure you have created a user account for the common name that you have specified and ensure that CN comparison is enabled for EAP-TLS.
kfarrington Wed, 02/04/2009 - 08:00
Hey Guys,
So this does mean by your thread that you can use Microsoft Active Directory to mange phones?
Ie, we dont want to use an ACS internal DB, so we can use AD?
Please confirm?
Many thx
