ACS command Authorization on PIX Console
May 20th, 2008
I have configured the pix firewall for ACS authentication and command authorization, everything is working fine
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ (inside) host 172.28.x.x x.x.x
aaa-server TACACS+ (inside) host 172.28.x. xx
aaa authentication ssh console TACACS+ LOCAL
aaa authentication serial console LOCAL
aaa authentication enable console TACACS+ LOCAL
aaa authorization command TACACS+
aaa accounting command privilege 15 TACACS+
aaa accounting enable console TACACS+
but porblem is that i dont wana have ACS authentication while connecting with console. In case of emergency when
ACS down, i wana to get console and access the device by using local username and password
but now after this configuration when i try to access the firewall via console, i m getting error of
command authorization fail.
I dont wana have any command authorization while connected with console, Please tell me how to resolve this issue
I have made the command authorization set in ACS and it is working fine for me,
Jagdeep Gambhir Tue, 05/20/2008 - 06:46
  • Red, 2250 points or more
Wasim,
Seems to be a bug, the issue we are facing with ASA v 7.2, where fall back to local authentication gives 'command authorization' failed with few commands has been files as a BUG.
Here is the bug tool link: CSCsj56051
http://www.cisco.com/cgi-bin/Support/Bugtool/home.pl
AAA authorization commands LOCAL fallback broken
Alternate Headline: AAA authorization commands LOCAL fallback broken
Symptom: aaa authorization fallback to LOCAL fails, blocking some commands to be executed and displaying "Command authorization failed" error message even though local authorization should be granted.
Conditions:
TACACS+ server communication is lost; LOCAL is configured next in the list.
Workaround: none.
Further Problem Description:
7.2.2 does not show this behavior
The issue is resolved in 007.002(002.034), 008.000(002.011),
008.002(000.045)
~JG
wasiimcisco Tue, 05/20/2008 - 12:54
kindly once again check my modified configuration,
I wanted to use this option in case, ACS goes down and i can console my firewall and but it is not working fine me.
aaa-server TACACS+ (edn) host 172.28.31.132
aaa-server TACACS+ (edn) host 172.28.31.133
aaa authentication http console LOCAL
aaa authorization command TACACS+ LOCAL
but i m not able to login i m getting following eror
TDC-INT-525-01> exit
TDC-INT-525-01> enable
i also defined the local command authorization set like this
privilege cmd level 15 mode exec command exit
privilege show level 5 mode exec command running-config
privilege show level 15 mode exec command version
privilege show level 0 mode exec command access-list
privilege show level 0 mode configure command access-list
privilege cmd level 15 mode configure command exit
privilege cmd level 15 mode configure command no
privilege cmd level 0 mode configure command access-list
privilege cmd level 15 mode interface command exit
privilege cmd level 15 mode subinterface command exit
privilege cmd level 15 mode dynupd-method command exit
privilege cmd level 15 mode trange command exit
privilege cmd level 15 mode route-map command exit
privilege cmd level 15 mode router command exit
privilege cmd level 15 mode ldap command exit
privilege cmd level 15 mode aaa-server-host command exit
privilege cmd level 15 mode aaa-server-group command exit
privilege cmd level 15 mode context command exit
privilege cmd level 15 mode group-policy command exit
privilege cmd level 15 mode username command exit
privilege cmd level 15 mode tunnel-group-general command exit
privilege cmd level 15 mode tunnel-group-ipsec command exit
privilege cmd level 15 mode tunnel-group-ppp command exit
privilege cmd level 15 mode mpf-class-map command exit
privilege cmd level 15 mode mpf-policy-map command exit
privilege cmd level 15 mode mpf-policy-map-class command exit
privilege cmd level 15 mode mpf-policy-map-param command exit
Please tell me how to solve this problem
Jagdeep Gambhir Tue, 05/20/2008 - 13:05
Is the issue happening only with console ? If ssh works fine then did the check the bug I mentioned in my last post ?
