ASA 5520 + CSC
May 20th, 2008
After configuration of 2 ASA 5520 with active/standby failover mode, I can't access to the Internet ( or very slowly) when the CSC is active.
There is no problem if the CSC is deactivate.
thanks for your help
hadbou Mon, 05/26/2008 - 13:17
  • Bronze, 100 points or more
Check the configuration of CSC SMM as any faults in the configuration may disable the access to internet.Also check for any filters(HTTP) for web links whuich may cause the issue you are facing.After installation of CSC SSM, by default your HTTP and FTP traffic is scanned for viruses, worms, and Trojans. Malware such as spyware and other grayware require a configuration change before they are detected
joel.gabriel Wed, 05/28/2008 - 05:37
Thanks for your help
I've just find the reason of my problem: I 'll need to upgrade the CSC software to test but I think is the solution.
