BGP advertise-map to track two or more prefixes (AND)
Answered Question
May 20th, 2008
Hello!
Need assistance!
I have two prefixes in BGP-table (p1, p2), received from other neighbors.
Third exist prefix (p3) I want to advertise only when BOTH prefixese are exist (p1 AND p2).
Tried this:
router bgp 100
network 30.30.30.30 mask 255.255.255.255
neighbor 1.1.1.1 advertise-map WHAT exist-map WHEN
ip prefix-list p1 permit 10.10.10.10/32
ip prefix-list p2 permit 20.20.20.20/32
ip prefix-list p3 permit 30.30.30.30/32
route-map WHAT permit 10
match ip address prefix-list p3
route-map WHEN permit 10
match ip address prefix-list p1 p2
Doesn't work :(
Router advertise p3 even one from two prefixes exist :(
Need "p1 and p2", but in real "p1 or p2".
Continue clause is not supported in condition route-map!
Also tried policy-list:
match policy-list list1
ip policy-list list1 permit
Doesn't work :(
Any ideas?
Correct Answer by Harold Ritter about 9 years 1 week ago
Narayan,
You are correct. It is not possible to create a condition that both prefixes have to be matched. What you can do though is the following.
Create an aggregate out of P1 and P2 and based your conditional advertisement the presence of attributes from both P1 and P2 on the aggregate route.
For instance, P1 could have a community of 1:1 and P2 a community of 1:2 and you could then use a setup similar to the following:
router bgp
aggregate-address x.x.x.x y.y.y.y as-set
route-map when permit 10
match ip address prefix-list aggregate
match community 1
ip community-list 1 permit 1:1 1:2
ip prefix-list aggregate permit x.x.x.x/x
You could set these communities using an inbound policy if they are not already set.
Overall Rating: 5 (1 ratings)
royalblues Tue, 05/20/2008 - 07:19
  • Green, 3000 points or more
You are correct.. i have seen this behaviour when the BGP conditional advertisement advertises the prefix even if any one of the match condition is true.
Problem is you cannot even have 2 match statements where in you can reference a prefix-list and also an access-list together
Now sure how to get around this for now. In the meantime lets see if someone else in this forum can point out a way
Narayan
Correct Answer
Harold Ritter Tue, 05/20/2008 - 09:49
  • Cisco Employee,
Narayan,
router bgp
match community 1
Sergey Zaytsev Tue, 05/20/2008 - 22:06
Hello!
Tried that....it WORKS:)
(as400 p1)----(as100 p3, agg)---(as300)
(as500 p2)-----/
Have prefix p1 from neighbor as400 with community 400:1, prefix p2 from neighbor as500 with community 500:1.
Making aggregate 10.0.0.0/8 with as-set and advertise-map Agg to create aggregate only from p1+p2.
Aggregate is for local use (outbound route-map filter! community additive in "aggregate attribute-map" not supported) with community of prefixes p1,p2 ("400:1 500:1").
Advertise prefix p3 to neighbor as300, as you said, with advertise-map (exist-map) match on aggregate prefix and community #1.
router bgp 100
network mask
aggregate-address 10.0.0.0 255.0.0.0 as-set advertise-map ADV
neighbor remote-as 300
neighbor route-map OUT out
neighbor advertise-map WHAT exist-map WHEN
neighbor remote-as 500
neighbor remote-as 400
ip community-list 1 permit 400:1 500:1
ip prefix-list agg seq 5 permit
ip prefix-list agg seq 10 permit
ip prefix-list p1-2 seq 5 permit 10.0.0.0/8
ip prefix-list p3 seq 5 permit
match ip address prefix-list p1-2
match community 1
route-map AGG permit 10
route-map OUT deny 10
route-map OUT permit 20
So, when both prefixes p1 and p2 are in bgp-table, prefix p3 advertise to neighbor as300.
as100#sh ip bgp nei | i Cond
Condition-map WHEN, Advertise-map WHAT, status: Advertise
When one of them is absent, aggregate's community is changing and p3's advertising is withdrawing!
Condition-map WHEN, Advertise-map WHAT, status: Withdraw
It's less easy then I thought (exist-map manipulation), but it WORKS :)
Thank you, HAROLD!
