Disabling / Enabling a port
eputman
Noob alert!! How do I go about disabling / enabling a port on a 3560?
Kevin Dorrell
Level 10
Level 10
Sw#conf t
Sw(config)#interface F0/4
Sw(config-if)#shut
Sw(config-if)#end
Sw#
Sw#conf t
Sw(config-if)#no shut
Sw(config-if)#end
Sw#
Kevin Dorrell
Luxembourg
9 Replies 9
acomiskey
Level 10
Level 10
config t
int fax/x
shutdown
config t
int fax/x
no shutdown
Kevin Dorrell
Level 10
Level 10
Sw#conf t
Sw(config-if)#shut
Sw(config-if)#end
Sw#
Sw#conf t
Sw(config-if)#end
Sw#
Kevin Dorrell
Luxembourg
Thanks Kevin. One more question how do i do it on a 6509?
same way...
As Adam says if the 6500 supervisor is running IOS then the same way.
If it is running CatOS
6500# set port disable 2/4
6500# set port enable 2/4
where 2/4 would be the 4th port on module 2 in the 6500 chassis.
Jon
If I want to see all the mac-address on a 6509 (not the port addresses but the computer addresses that are connected to the 6509 what is the command?
I tried sh port mac-address 4 but that gave me all the port mac-addresses and not the computers. Help..
For 6500 with CatOS you will need
6500# show cam dynamic
to display all mac addresses
and
6500# show cam dynamic 6/20
to display the mac address on module 6 on port 20
yes-----
you can filter the Vlans as for Vlan 6 type
Shaheen
Is there a way to filter by vlan so i don't see all my 500+ mac addresses?
I have already answered in my above email. please try and update us if it has worked ?
Shaheen
