PPTP Support/Configuration on PIX 515 with Pixos 8.0.3
May 20th, 2008
Hi All;
I have been trying to configure a PIX 515 with Pixos 8.0.3 to accept PPTP VPN connection and i have been failing miserably! Maybe this is only possible on version 6.x and not on 8.x.
I have been able to configure L2TP with IPSec and that is working well, but what i need is PPTP without IPSec, so a windows application can connect to it, my current configurations is as follows:
Thank you
Lucio
aaa-server vpn protocol radius
aaa-server vpn host 192.168.1.10
key windows
http server enable
http PublicHomeNetwork 255.255.255.0 outside
http 192.168.1.0 255.255.255.0 dmz
http 172.16.1.0 255.255.255.0 inside
http 10.10.10.1 255.255.255.255 inside
http 192.168.1.0 255.255.255.0 inside
crypto ipsec transform-set TRANS_ESP_3DES_MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set TRANS_ESP_3DES_MD5 mode transport
crypto dynamic-map outside_dyn_map 20 set transform-set TRANS_ESP_3DES_MD5
crypto map outside_map 20 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 5
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
dns-server value 78.186.13.51
vpn-tunnel-protocol IPSec l2tp-ipsec
default-domain value nonono.com
username test password xxx
tunnel-group DefaultRAGroup general-attributes
address-pool clientVPNpool
default-group-policy DefaultRAGroup
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
tunnel-group DefaultRAGroup ppp-attributes
no authentication chap
authentication ms-chap-v2
Overall Rating: 4 (1 ratings)
I stand corrected - but the last time I checked, you cant terminate PPTP of ver 6.4 and above...you can only configure IPSEC and L2TP tunnels to terminate.
I think now with ver 8.x you can configure PPTP pass-thru to terminate the PPTP tunnel on a backend server in your LAN!
HTH.
