Cannot choose option on Auto-attendant
Answered Question
May 20th, 2008
I have implemented the IP Phone on CUCM 5.0. When I call any call centre that implement auto-attendant/IVR/operator that instruct me to choose menu
For english , press 1
For french, press 2
When I choose 1 or 2 or else on the keypad, why the option is not entered? Is it DTMF problem?
Correct Answer by Anonymous (not verified) about 8 years 5 months ago
Coud you provide the details of the sript. Are you using a custom script. If youa re facing some issues with the custom script you can contact the developer support at
Paolo Bevilacqua Tue, 05/27/2008 - 02:07
Check that both on CCM and the device you have configured a compatible DTMF relay method.
Paolo Bevilacqua Tue, 05/27/2008 - 03:06
Look, if you're using a SIP trunk ot ITSP, often none works and you have to send tones in-band.
Sorry I'm not expert at configuring the CCM, so hopefully somebody else can help you.
