LMS 2.6 / RME : SWIM failed for 26XX
May 20th, 2008
On LMS 2.6, we can't upload or download IOS for 26XX, job failed.
You can find IOS version and hardware type:
Cisco IOS Software, C2600 Software (C2600-SPSERVICESK9-M), Version 12.3(11)T2, RELEASE SOF
TWARE (fc1)
Cisco 2610XM
IOS (tm) C2600 Software (C2600-IS-M), Version 12.1(17), RELEASE SOFTWARE (fc1)
cisco 2612
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(13)T, RELEASE SOFTWARE (fc1)
cisco 2611XM
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(8)T4, RELEASE SOFTWARE (fc1)
cisco 2621XM
cisco 2610XM
cisco 2611XM
26XX are supported on RME 4.0.5 and I didn't find bug.
Many thanks for help,
Elisabeth
Joe Clarke Tue, 05/20/2008 - 17:14
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to enable SoftwareManagement debugging under RME > Admin > System Preferences > Loglevel Settings, then run a new job for one failing device. Then post the job directory.
ebezombes Fri, 05/30/2008 - 06:03
Hi Joe,
Here you can find job folder.
I didn't find bug on ios which could explain this issue.
Elisabeth
Joe Clarke Fri, 05/30/2008 - 09:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The device appears not to like the server address of 10.104.140.204. If this the correct address for the RME server? Should the device be able to initiate a TFTP session to this address?
ebezombes Thu, 06/05/2008 - 04:45
This is the good IP address, I think that tftp session can be initiate to this IP.
Elisabeth
Joe Clarke Thu, 06/05/2008 - 08:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You might want to try this manually to make sure. Create a file on the LMS server under NMSROOT\tftpboot. Then connect to the device, and try to copy the config to that same address using the filename you created under tftpboot. Does it work?
ebezombes Tue, 06/10/2008 - 04:25
Manually it works:
CACB0226#copy flash:D1246T.SPS tftp
Address or name of remote host []? 10.104.140.204
Destination filename [D1246T.SPS]? test.bin
26614684 bytes copied in 2220.913 secs (11984 bytes/sec)
Elisabeth
Joe Clarke Tue, 06/10/2008 - 08:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It looks like these drops are tripping up the SNMP code. Can you try using another protocol like RCP or SCP? Either that, or fix up the network so as not to generate so many lost packets.
