upgrading the WLC 2006 controller
May 20th, 2008
i need to upgrade my WLC from 3. to 4. version but this is the first time i've had to upgrade a controller. So I'm not sure what to expect.
Any pointers I should know before going into that project?
jeromehenry_2 Tue, 05/20/2008 - 23:17
  • Silver, 250 points or more
Most welcome. Depending which version you come from, you might have to upgrade both the code and the bootloader (in which case you will see in the download section a boot file along with the normal code file). In this case, do spend a few minutes reading the release notes, and update the bootloader before the code itself.
Cheers
Jerome
garyrivers Wed, 05/21/2008 - 05:32
well, i'm going from 3.2.171.6 to 4.0 so I'm hoping there isn't an issue.
but I will take your advice and checkout the release notes.
Gary
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
