How to remove/delete CSS script from directory
Answered Question
May 20th, 2008
it's clear to me how to upload, rewrite or execute the script on CSS.
copy ftp myaccount disable-sticky.txt script disable-sticky
script play disable-sticky
but, I could not find out how to delete the script from CSS script directory.
Vladimir
Correct Answer by ciscocsoc about 8 years 8 months ago
Hi Vladimir,
Use the clear command.
clear {log filename|script filename|archive filename|
startup-config}
Use show disk to get the slot number (probably 0) and then do:
clear 0 script disable-stciky
You need to be in superuser mode to do this.
Cathy
Overall Rating: 5 (2 ratings)
Correct Answer
ciscocsoc Tue, 05/20/2008 - 23:51
Hi Vladimir,
startup-config}
Cathy
