NAT VPN no traffic, 106014 deny inbound
May 20th, 2008
I'm not sure if this should go in the Security section or here, but perhaps someone can help with this configuration?
Trying to NAT the internal IP to another subnet so the destination end doesn't clash. The tunnel comes up fine, but traffic does not pass over it. If I send a ping to the destination, it gives "106014 deny inbound icmp src inside:192.168.7.20 dst outside:192.168.27.40 (type 8, code 0)". I know there's something fundamental wrong, but can't spot it.
Local site 192.168.7.0, local NAT to 192.168.17.0, remote site 192.168.27.0.
TIA!
access-list outside_access_in extended permit ip 192.168.27.0 255.255.255.0 192.168.17.0 255.255.255.0
access-list SiteName_access extended permit ip 192.168.27.0 255.255.255.0 192.168.7.0 255.255.255.0
access-list SiteName_NAT extended permit ip 192.168.7.0 255.255.255.0 192.168.27.0 255.255.255.0
access-list SiteName_cryptomap extended permit ip 192.168.17.0 255.255.255.0 192.168.27.0 255.255.255.0
nat (inside) 0 access-list inside_nat0_outbound
nat (outside) 0 access-list outside_nat0_outbound
static (inside,outside) 192.168.17.0 access-list SiteName_NAT
access-group outside_access_in in interface outside
route outside a.b.c.d 255.255.255.255 outside_router 1
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto map outside_map 3 match address SiteName_cryptomap
crypto map outside_map 3 set pfs
crypto map outside_map 3 set peer a.b.c.d
crypto map outside_map 3 set transform-set ESP-AES-256-MD5
crypto map outside_map 3 set security-association lifetime seconds 3600
crypto map outside_map 3 set reverse-route
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 20
authentication pre-share
encryption aes-256
hash md5
group 2
lifetime 28800
no crypto isakmp nat-traversal
group-policy SiteName internal
group-policy SiteName attributes
vpn-filter value SiteName_access
vpn-tunnel-protocol IPSec
tunnel-group a.b.c.d type ipsec-l2l
tunnel-group a.b.c.d general-attributes
default-group-policy SiteName
tunnel-group a.b.c.d ipsec-attributes
pre-shared-key Mykey
gluker7388 Wed, 11/04/2009 - 19:07
did you ever get an answer for this error? i am having the exact same problem. I have tryed everything and nothing works.
