Indoor coverage with outdoor equipment
May 20th, 2008
Sr, I need to provide coverage in all apartments in a building of four floors. I can't install indoor Access Point because bureaucratic subjects. I need provide this coverage using outdoor equipment.
Somebody already made something similar.
thanks !
Overall Rating: 3 (1 ratings)
jeromehenry_2 Wed, 05/21/2008 - 00:41
Do you mean using outdoor access points indoor or covering indoor from the outside?
In the first case (using outdoor access points indoor) I saw in done in a shopping mall, ti does work properly, even if site survey is a bit of an issue (You need higher mounting for the APs and the amplifier creates coverage patterns and reflections issues a bit specific).
In the second case (covering indoor from access points placed outside), it is more challenging. The penetration power of a wireless wave is not great, you would probably cover well through the windows but have a lot more difficulties through the external walls... depends of course on the building, but I would be cautious...
rezende.c Wed, 05/21/2008 - 04:51
thanks Jerome,
My case is the second case. I intend use 1510 Access Points. I will make a site survey to validate this.
jeromehenry_2 Wed, 05/21/2008 - 05:16
Good luck Claudio then!
Everytime I tried I had disapointing results, coverage was fine at the edge of the buildings and poor inside...
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
