WebVPN Issues
May 20th, 2008
Hi All,
I have a strange problem with webvpn.
When a client computer sets up a ssl webvpn connection to our office. And then wants to connect to a MS file share. It's very slow. It takes about 5 min before the file share appears.
I have checked the following:
1) Pinging to the fire server & DNS: Ok quick reply.
2) Nslookups on the dns names: OK for all server.
3) checked ip setting: OK
4) checked route: OK.
5) virusscan check: OK (because of java)
And the strange thing is that when I install a cisco vpn VAT client on the computer. (But don't use it). And then connect through webvpn every think is fast.
Also when i use the VAT VPN client it's fast.
But when i unstall the VAT VPN client everything is slow again.
I hope some can give me any suggestions.. Because I'm stuck at the moment…
owillins Mon, 05/26/2008 - 13:18
  • Silver, 250 points or more
Better solution is MTU adjustment. Try to lowering the MTU and try again and check any issues .
