tcp idle connections
Answered Question
May 20th, 2008
I have a customer that runs large oracle queries (1521)that the PIX sees as idle connections. I've tried classifying the traffic and using polic-maps to set the connection to not timeout (0:0:0) with no luck. Any suggestions?
Correct Answer by smahbub about 9 years 2 months ago
Can you provide more information about the issue you are facing and also the output of "show tech" which will help us in finding a better solution after identifying the cause of the issue.
Overall Rating: 5 (1 ratings)
Correct Answer
smahbub Mon, 05/26/2008 - 13:23
  • Silver, 250 points or more
kyoung77 Mon, 05/26/2008 - 16:07
Thanks for the reply, it was a bug in code that was fixed in a later version.
Again Thanks!
