Dot1X removed but still coming up in logging
May 20th, 2008
I removed all instances of Dot1x on my Cat3560. I keep getting alerts from Cisco Works.
I am now keep getting alerts in Cisco Works. The below is a sh logging on the switch. It is getting the same error below on random ports at random times.
Any ideas what needs to be done to clear the dot1x errors? I havent rebooted the switch since I removed dot1x info from the switch.
173965: .May 20 11:39:11.298 UTC: dot1x-registry:** dot1x_switch_vp_statechange:
173966: .May 20 11:39:11.298 UTC: dot1x-ev:vlan 10 vp is removed on the interfac
e GigabitEthernet0/39
173967: .May 20 11:39:11.298 UTC: dot1x-registry:dot1x_switch_pm_handle_vlan_rem
oval invoked oninterface GigabitEthernet0/39 removed_vlan= 10
173968: .May 20 11:39:11.307 UTC: dot1x-registry:dot1x_switch_port_physical_link
change invoked on interface Gi0/39
david.santel@es... Tue, 05/20/2008 - 10:57
Here is another port thats doing it!
What the heck did DOT1X do to my switch.
173989: .May 20 11:55:02.191 UTC: dot1x-registry:** dot1x_switch_vp_statechange:
173990: .May 20 11:55:02.191 UTC: dot1x-ev:vlan 10 vp is removed on the interfac
e GigabitEthernet0/6
173991: .May 20 11:55:02.191 UTC: dot1x-registry:dot1x_switch_pm_handle_vlan_rem
oval invoked oninterface GigabitEthernet0/6 removed_vlan= 10
173992: .May 20 11:55:02.200 UTC: dot1x-registry:dot1x_switch_port_physical_link
change invoked on interface Gi0/6
173993: .May 20 11:55:03.198 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interfac
e GigabitEthernet0/6, changed state to down
173994: .May 20 11:55:04.204 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet0/6,
173995: .May 20 11:55:04.532 UTC: dot1x-registry:dot1x_switch_port_linkcomingup
173996: .May 20 11:55:04.557 UTC: dot1x-registry:** dot1x_switch_vp_statechange:
173997: .May 20 11:55:04.557 UTC: dot1x-ev:vlan 10 vp is added on the interface
GigabitEthernet0/6
173998: .May 20 11:55:04.557 UTC: dot1x-ev:dot1x_switch_is_dot1x_forwarding_enab
led: Forwarding is disabled on Gi0/6
173999: .May 20 11:55:06.537 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet0/6,
changed state to up
174000: .May 20 11:55:07.543 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interfac
e GigabitEthernet0/6, changed state to up
david.santel@es... Tue, 05/20/2008 - 11:19
I fixed it. I had debug dot1x all on.
But why would it be doing any dot1x at this time since I removed everything related to dot1x from the switch?
