Cisco VPN Client on Leopard 10.5.2
May 20th, 2008
I am running Cisco VPN client 4.9.01(0100) and am experiencing difficulties connecting to our Cisco 3000 concentrator. It seems that I can connect and authenticate no problem, and from the concentrator everything looks fine. Once authentication is complete however I have no connectivity either to the remote network or my local network. Pinging either the local gateway or the remote internal network nets me a "sendto: Network is unreachable" error. The client stays connected for about 5 minutes before being kicked off by the concentrator.
On my Tiger (10.4.x) laptop the client (4.7.x) works flawlessly using the same account information. Is anyone else experiencing this?
I have attached a log file. It shows that everything seems to hook up properly and then it suddenly stops getting any love.
Any help would be greatly appreciated!
Sean.
dinesh.das Thu, 05/22/2008 - 01:18
Verify your configuration on concentrator and Client whether you allowed the LOCAL LAN or not
sean.page Thu, 05/22/2008 - 06:22
The client is set to allow local LAN access, which has always worked in the past...
