EZvpn 851 to ASA 5510 Version 8.0
May 20th, 2008
OK, I am stumped. I created the VPN connection, have it auto xauth, VPN comes up, but I cant route. What do I need to do the get routing established?
The networks I need to reach are 10.14.0.0/24, .1.0, .2.0, and .3.0 /24 which are behind the ASA, the remotes will be 10.14.5.0, 16, 32, and 48 /28.
I followed http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080809222.shtml
and get NEM_Remote_Subnets=10.14.5.0/255.255.255.240 10.14 on the 851, but cant ping across from a machine behind the 851 to a server behind the ASA.
tahequivoice Thu, 05/22/2008 - 11:14
I found the problem, the document I linked to has an error.
access-list Split_Tunnel_List standard permit 192.168.10.0 255.255.255.0
This is supposed to push what traffic to encrypt to the client, but it is the clients network that is listed. Once I discovered that I had the wrong network being sent to the client, the split tunnel started working. The correct ACL should be
access-list Split_Tunnel_List standard permit 10.10.10.0 255.255.255.0 which is the network of the ASA.
Once I got split tunneling working, it was a matter of getting the no nat working since there are more than 3 remote 800 routers using Ezvpn to connect to this ASA along with Cisco VPN clients.
