ASA correct mounting brackets
May 20th, 2008
Has anyone has any problems with the mounting brackets that they send with the ASA? I have a 5520 with one of those T looking bracets. When you install the devices facing the front, the part where it looks like a T extend beyond the device and doesn't flush mount. It works fine if you instal the device with the back facing forward. I wonder if I got the wrong bracket, or if that's the way they are sent nowadays.
thanks.
vitripat Thu, 05/22/2008 - 07:37
  • Gold, 750 points or more
The T bracket accommodates a grounding lug. It also allows a place to plug in an ESD wrist strap when working on the unit.
Hope that helps.
Vibhor.
ty.masse Thu, 05/22/2008 - 14:01
I see what you guys are saying. It just doen't look good in a rack with that thing sticking out. Thanks for your responses anyways.
