Can we simulate HSRP configuration using 1x2600 & 1x3560
I was just wondering whether we can simulate HSRP failover by using one 2600 router and one 3560 switch where i have 2 FE interfaces at 2600?
I have connected the 2 FE interfaces from 2600 to 3560 switches with 2 routed ports configured respectively and hook up a laptop to 3560 port and did a continuous ping to 2600. However, I did not see the failover when i manually shutdown one interface at the 2600 FE.
Anyways that i can simulate it?
Edison Ortiz Tue, 05/20/2008 - 17:22
In order to have HSRP running, both HSRP devices must be on the same LAN.
Can you provide configs along with the show stand output from both devices?
Thanks!! I will provide the config later on. Meantime, I have tried to configure the 2 FE interface in 2600 with same LAN IP range but failed to do so. ie. FE0/0 IP, FE0/1 IP Hence, I changed the FE0/1 IP to The routed ports are configured as follows:
FA0/1: connected to FE0/0
FA0/2: connected to FE0/1
My laptop IP is in VLAN10 on 3560.
My ping is to IP) to 2600.
So I think my configurations won't work now since the interfaces are on different segment. Anyway to configure 2600 FE0/0-1 with same segment?
srue Wed, 05/21/2008 - 04:24
try configuring one of the ports on your router and a vlan interface on a switch as an hsrp pair.
Edison Ortiz Wed, 05/21/2008 - 04:38
HSRP configuration requires you to share this task within (2) physical devices.
You can configure HSRP between the 2600 Router and the 3560 switch.
You already have a Vlan10 on the 3560. I recommend changing the IP on one of the interfaces in the 2600 router to be on that Vlan. Configure the switchport for access-vlan 10, then configure HSRP between Vlan10 Layer3 interface in the switch and the fastethernet in the router connected to that Vlan.
You mean I should configure as follows:
FE0/0 IP
FE0/1 IP
Int Fa0/1
Description Connect to FE0/0
no switchport
ip addr
Int Fa0/2
Description Connect to FE0/1
switchport access vlan 10
switchport mode access
Int Vlan10
ip addr
Standby 1 IP
Standby 1 preempt
My laptop IP is in VLAN10 connected to 3560.
I ping to IP) to 2600.
Is it correct?
Edison Ortiz Thu, 05/22/2008 - 05:25
Yes, that should do it.
Once you are done with that configuration, please post the show stand for verification.
