CDR :- cdr is not updating the some extension call records
May 20th, 2008
ccm 4.1.3
network desging publisher and subscriber
all phones are registerd with subscriber
i am trying to pull the cdr information form the cdr database, but i successfully pull the cdr information from the cdr, after that i found out some extensions call details is not recording correctly, last three months some phone call details is only one or 3 like that problem i am getting if some extension no problem. i getting all details correctly, this problem i am facing
smalkeric Mon, 05/26/2008 - 13:31
  • Silver, 250 points or more
Verify that "Cisco CDR Insert" and "Cisco CDR Analysis and Reporting Scheduler" services are running only in the Publisher
Call Manager
CCM Service Parameters:
CdrEnabled = True
CdrLogCallsWithZeroDurationFlag = True
Call Diagnostics Enabled = True
DBL Service Parameter:
Max CDR Records = 1500000
Enterprise Parameters:
Local CDR Path = C:\Program Files\Cisco\CallDetail
CDR UNC Path = \\\CDR
CDR Format = CDRs will be inserted into database
CDR File Time Interval (min) = 1
Please restart the following services (after hours):
1) Restart service "Cisco database Layer Monitor" on publisher and subscriber servers.
2) Restart service "Cisco CDR Insert" on the publisher server.
3) Restart service "Cisco CDR Analysis and Reporting Scheduler" on the publisher server.
