debug status not display
May 20th, 2008
I am trying to debug bgp all and its not display any thing, is there any configuration for the same.
interface Loopback0
ip address 192.168.40.40 255.255.255.255
interface FastEthernet0
ip address 10.97.37.211 255.255.255.0
speed auto
interface Serial0
ip address 192.168.30.1 255.255.255.0
encapsulation frame-relay
frame-relay interface-dlci 200
frame-relay lmi-type ansi
interface Serial1
ip address 172.26.8.1 255.255.255.0
router bgp 65003
no synchronization
bgp log-neighbor-changes
redistribute connected
neighbor 192.168.40.30 remote-as 65003
neighbor 192.168.40.30 update-source Loopback0
no auto-summary
ip route 192.168.40.0 255.255.255.0 192.168.30.2
ip route 192.168.40.0 255.255.255.255 192.168.30.2
no ip http server
no ip http secure-server
ankbhasi Wed, 05/21/2008 - 01:25
  • Cisco Employee,
Hi Manju,
Have you telnetted into the router/switch and then enabling debug? If yes issue a command "terminal monitor" and then update if you see anything in debugs or not?
Ankur
*Pls rate all helpfull post
ntmanjunath Wed, 05/21/2008 - 02:24
Hi Ankur,
Yes am telnetted to router.
Where to configure this command ? "terminal monitor"
cisco_lad2004 Wed, 05/21/2008 - 02:23
  • Gold, 750 points or more
in addition to previous reply , u may want to logg to memory. add commmand "logging buffered X" where X is the memory amount you choose ( I have it set to 100,000.
Sam
ntmanjunath Wed, 05/21/2008 - 02:46
I added the command "logging buffered 100,000 "and still its not showing anything.
regards,
Pravin Phadte Wed, 05/21/2008 - 02:55
  • Silver, 250 points or more
did u tried the terminal monitor
router#terminal monitor
router#terminal no monitor
cisco_lad2004 Wed, 05/21/2008 - 03:08
try "logging monitor debugging "
in ur case Router(config)# logging monitor 7 ( to include debugging).
Sam
ntmanjunath Wed, 05/21/2008 - 03:35
I added the configuration and still the problem is same.
AIRTEL-PE1(config)#logging monitor ?
<0-7> Logging severity level
alerts Immediate action needed (severity=1)
critical Critical conditions (severity=2)
debugging Debugging messages (severity=7)
discriminator Establish MD-Console association
emergencies System is unusable (severity=0)
errors Error conditions (severity=3)
filtered Enable filtered logging
informational Informational messages (severity=6)
notifications Normal but significant conditions (severity=5)
warnings Warning conditions (severity=4)
xml Enable logging in XML
AIRTEL-PE1(config)#logging monitor 7
AIRTEL-PE1(config)#logging monitor debb
AIRTEL-PE1(config)#logging monitor debugging
cisco_lad2004 Wed, 05/21/2008 - 04:18
pls paste a show logg output, just 1st few lines.
Sam
ntmanjunath Wed, 05/21/2008 - 23:48
Please see the output.
AIRTEL-PE1#sh logging
Syslog logging: enabled (1 messages dropped, 0 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 3703 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 17 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
No active filter modules.
Trap logging: level informational, 3349 message lines logged
Log Buffer (100000 bytes):
cisco_lad2004 Thu, 05/22/2008 - 00:01
Ur config looks ok, u are getting messages on console logging and buffered but not on monitor mode.
1-are there no BGP log messages when u do show log ?
2-debug while u have terminal monitor on.
3-try to create BGP logs by creating a dummy session where there is no other BGP peer at other end.
Sam
ntmanjunath Thu, 05/22/2008 - 01:00
Console logging: level debugging, 3704 messages logged, xml disabled,
filtering disabled
filtering disabled
Buffer logging: level debugging, 18 messages logged, xml disabled,
filtering disabled
Trap logging: level informational, 3350 message lines logged
cisco_lad2004 Thu, 05/22/2008 - 03:27
u must have some lines in log, since I see
"Buffer logging: level debugging, 18 messages logged, xml disabled, "
