CCNA certification exam query
May 20th, 2008
Hi all,
Can someone help me out with the CISCO router model included in the latest CCNA exam? Which router to study?
Cowsika S Dasarathan Wed, 05/21/2008 - 00:38
Normally CCNA exams can be practiced using entry level routers. Depending on the budget I would suggest to use 17xx series or 26xx series routers and it would satisfy all the requirement for CCNA Topics and also for CCNP Level exams. And you may also want to consider 28xx series if you have more budget.
milind.v.patil Thu, 05/22/2008 - 22:00
Many Thanks.
I have a 2600 series router. Can i create 5 login users for it? If yes, then how?
Also if i want to delete one of them, then how?
