Access level to a user on Network Device group
Answered Question
May 20th, 2008
1. In ACS is it possible to give Readwrite access to an user when he logs in to a Network device group and readonly access when he logs in another network device group.
Thanks in advance
Correct Answer by Jagdeep Gambhir about 8 years 8 months ago
You need to set up Command Authorization Set on a per Network Device Group Basis
Assign a Shell Command Authorization Set on a per Network Device Group Basis-Associates particular shell command-authorization sets to be effective on particular NDGs.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.1/user/GrpMgt.html#wp480029
~JG
Overall Rating: 5 (1 ratings)
Cowsika S Dasarathan Wed, 05/21/2008 - 08:13
In the access restrictions section located in group setup tab, for the specific user-group, you would be able to set the permission. There will be a section enable options wherein you can specify permission for each each device or each network device group.
Correct Answer
Jagdeep Gambhir Wed, 05/21/2008 - 18:00
~JG
anva12345 Thu, 05/22/2008 - 04:22
Hi all,
We have successfully configured the User level access to different network device groups. this was accomplished by configuring different network device and Shell command authorization set.
Thanks for all your help.
