Key Management
May 21st, 2008
I'm trying to set the VPN Key Management to DH 5 on ASA 5510. The VPN client is not able anymore to set up the VPN connection. When using DH 2, everything works ok.. Does the client not support DH Group 5 ?
michael.leblanc Fri, 05/23/2008 - 12:56
If you do an ISAKMP debug you'll see the IKE transforms being proposed by the client. That will likely confirm your beliefs.
