Memory usage on firewalls
May 21st, 2008
Good morning,
I manage both a pix515 and an ASA5510. I noticed that memory usage indicated in PDM and in ASDM is different from value I obtain with show mem command. Is it normal or is there a bug in pdm/asdm?
Overall Rating: 1 (1 ratings)
smahbub Tue, 05/27/2008 - 05:57
"Show Memory" command is used to display a summary of the maximum physical memory and current free memory available to the operating system.You can use the show memory detail output with show memory binsize command to debug memory leaks.
Refer the following url for more info about the "show memory" command
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/s4.html#wp1393245
