RME device update problem
May 21st, 2008
Dear All,
I updated device pacakges using web. Error was shown during the update. Here I sent the event log :
Number of Packages Selected for Install : 1
For Product(s) : Resource Manager Essentials
Install Invoked by user : admin
The Package(s) Selected for Install :
Rtr2800
ERROR: Error while installing (LibCommon): C:PROGRA~1CSCOpx emppsuinstall
meLibCommon.zip cannot be installed because, the current mdf version:1.12 is LESS THAN the minimum required mdf version:1.19
ERROR: Error while installing (LibInventory): C:PROGRA~1CSCOpx emppsuinstall
meLibInventory.zip cannot be installed because, the current mdf version:1.12 is LESS THAN the minimum required mdf version:1.19
ERROR: Error while installing (Rtr2800): C:PROGRA~1CSCOpx emppsuinstall
meRtr2800.zip cannot be installed because, the current mdf version:1.12 is LESS THAN the minimum required mdf version:1.16
ERROR: Error while installing (SharedInventoryRouter): C:PROGRA~1CSCOpx emppsuinstall
meSharedInventoryRouter.zip cannot be installed because, the current mdf version:1.12 is LESS THAN the minimum required mdf version:1.19
ERROR: Error while installing (SharedSwimIOS): C:PROGRA~1CSCOpx emppsuinstall
meSharedSwimIOS.zip cannot be installed because, the current mdf version:1.12 is LESS THAN the minimum required mdf version:1.19
ERROR: Error while installing (LibSwim): C:PROGRA~1CSCOpx emppsuinstall
meLibSwim.zip cannot be installed because, the current mdf version:1.12 is LESS THAN the minimum required mdf version:1.19
No package(s) to install for : Resource Manager Essentials
Any suggestion about what should I do ?
Thanks in advance.
Overall Rating: 4 (1 ratings)
David Stanford Wed, 05/21/2008 - 05:34
  • Cisco Employee,
You need to install the mdf package version 1.19 or higher which can also be added via the Device Updates.
However, to get MDF select to check for updates for Common Services. It should list 1.21 as the latest.
0600648902 Wed, 05/21/2008 - 19:11
Ok, I'll try it.
I also got problem when updating RME device package.
For Product(s) : rme
SharedDcmaIOS
WARNING : SharedDcmaIOS(1.6.3):minor versions are incompatible.Required version 1.8 for LibDcma package
Installation Completed for : rme
I have tried to find the 1.8 or latest version of SharedDcmaIOS package, but I found nothing. What should I do ?
Thanks in advance.
0600648902 Thu, 05/22/2008 - 21:26
I know I have to install it, but I can't find any dev package at cisco.com to fulfil this requirement. Any help ?
Martin Ermel Fri, 05/23/2008 - 06:04
  • Blue, 1500 points or more
exactly which version of LMS do you have? (and CS and RME)
If I know well, there are some RME device packages which cannt be downloaded from CCO but gets installed with Software Updates for RME. An example is the update from LMS 2.5.1 to LMS 2.6 which brings RME from 4.0.3 to version 4.0.5)
MDF 1.12 is quite old and I think it is time for you to update LMS completely.
0600648902 Sun, 06/08/2008 - 00:30
You are right. After I upgrade to LMS 2.6, everything is going fine. Thanks.
