S2S VPN Error
May 21st, 2008
My customer is trying to establish a VPN connection from his network to our network.
However, the VPN connection cannot be established. Following is the error:
2008-05-20 15:16:22 Local4.Error yy.yy.yy.yy %ASA-3-713119: Group = xx.xx.xx.xx, IP = xx.xx.xx.xx, PHASE 1 COMPLETED
2008-05-20 15:16:22 Local4.Notice yy.yy.yy.yy %ASA-5-713904: Group = xx.xx.xx.xx, IP = xx.xx.xx.xx, All IPSec SA proposals found unacceptable!
2008-05-20 15:16:22 Local4.Error yy.yy.yy.yy %ASA-3-713902: Group = xx.xx.xx.xx, IP = xx.xx.xx.xx, QM FSM error (P2 struct &0xd5a88fe0, mess id 0x6848403d)!
2008-05-20 15:16:22 Local4.Error yy.yy.yy.yy %ASA-3-713902: Group = xx.xx.xx.xx, IP = xx.xx.xx.xx, Removing peer from correlator table failed, no match!
2008-05-20 15:16:22 Local4.Warning yy.yy.yy.yy %ASA-4-113019: Group = xx.xx.xx.xx, Username = xx.xx.xx.xx, IP = xx.xx.xx.xx, Session disconnected. Session Type: IKE, Duration: 0h:00m:00s, Bytes xmt: 0, Bytes rcv: 0, Reason: Phase 2 Mismatch
How can I find out what may go wrong?
shmathur Wed, 05/21/2008 - 02:48
Please look at Phase 2 IPSEC policy settings on both the VPN gateway in questions, like transform-set, PFS (enabled or disabled) and crypto ACL. All these parameters should exactly match on both the VPN endpoints.
Hope it helps.
